Pict2Ascii-1.03-src.sit
Download: http://archive.info-mac.org/dev/src/pic ... 03-src.hqx
This is the source code for Pict2Ascii, available somewhere else
in the archive as Pict2Ascii-FAT-1.03.sit.
The only change since 1.02 is the support for scriptability.
Pict2Ascii is a freeware than interactively generates texts that
"look like" the pictures you feed it with, giving you control
over various settings.
The source code is heavily based on C++ and PowerPlant (CW10).
I make it available as an exemple of what a "real" app can look
like with PowerPlant, while small enough to be mastered easily.
I don't claim it is well written or particularly clever, but hey,
it works not too bad !
This code is free, but not in the public domain. See the loose
reuse conditions enclosed.
