Hynoptic SDK
Hynoptic SDK
Download: http://archive.info-mac.org/app/ss/hypn ... dk-201.hqx
If you want to write savescreen, stand-alone, modules for HypnOptic
Savescreen System you should use this Software Development Kit. Even if
you are a beginner in programming you may build, and sell, your own
savescreen application! The SDK project lets you concentrate only on the
creative part of developing: the main, and more tedious, part of work is
already done. You may simply change the contents of one routine to have a
new savescreen. If you're more experienced, instead, you may add routines,
change resources and create explosive images.
HypnOptic Modules are Appearance savvy and require at least System 7 to run.
New since version 2.0.0
Better project setting. Addresses update
Author: Rocco Moliterno
mailto:[email protected]
http://yellowsoft.tsx.org/
HypnOptic page:
http://www.geocities.com/SiliconValley/ ... optic.html
