File-Adopter-1.0.dmg
Download: http://archive.info-mac.org/disk/file-adopter-10.hqx
File Adopter 1.0 is now available.
File Adopter uses your Internet Config preferences to add type and
creator codes to files that lack them. Typeless files are common on Mac
OS X, and are a source of numerous frustrations. File Adopter works with
simple drag and drop. It can replace existing type and creator codes if
they disagree with Internet Config, or only add codes when they are
absent. After adopting a file, it shows you the changes it has made. You
can also hold down Shift to orphan a file, instead of adopting it. This
is useful if you know that the file has incorrect codes but that the
correct ones aren't in Internet Config.
More Information:
