FileDispenser optimizes file management by applying filters when copying
or moving files from a Source Folder. A Source Folder may be any folder,
drive or CD. Files are identified and categorized according to your choice
of file attribute such as format, application that create/edit the file,
date the file was modified or file name (alphabetically or numerically,
file Prefix or Suffix). FileDispenser also watches an user-defined
hot-folder, checking periodically, copy or move files that been dropped in
the hot-folder and categorizes them while copying.
