Filemunger
Filemunger
Download: http://archive.info-mac.org/disk/filemunger-10.hqx
FileMunger - is a Shareware utility that lets you use "Drag and Drop" to easily:
Add date stamps to files and folders. "MyFile" -> "MyFile-10/28/99". Many
differrent formats are allowed. Add, remove or change file extensions.
"MyFile.htm" -> "MyFile.html". Change file Creator and Type codes. "ttro ttxt" ->
"TEXT ttxt" etc. Requires Mac OS 8 or up and a PowerPC (anything but 68K
machines). Support: http://members.aol.com/halfhill
