FileShield SDK 1.0
FileShield SDK 1.0
Download: http://archive.info-mac.org/disk/fileshield-sdk.hqx
FileShield SDK 1.0
Mindscope Software
Freeware
Now you can include support for unshielding FileShield 1.0 encrypted
files in your software! This simple to use interface allows you to
unencrypt '.icp' files in your application with a single command! Make
sure that you include the 'UnShield.rsrc (DLOG)' resource file in your
project, or your program will crash. This software was written and
intended for Codewarrior Pascal.
(Mindscope is not responsible for any damages that may result from
using this software or including it in your application framework. We
have tested the software thoroughly and no problems have arisen, but
know that you use this at your own risk!)
