Download: http://archive.info-mac.org/disk/filetc-220.hqx
FileT&C is an useful application for changing file type and/or creatorŠ
It's very useful for normal desktop usage, but is really cool when works,
fine, fast and in background, with a lot of files. Also it can scan,
quickly, disks and folders looking for files to treat...
FileT&C is Internet Config aware and has a couple of options to change,
according to name extension, following the Internet Config's File Mapping
setting.
FileT&C has some useful hot keys for changing, on the fly skipping the
"Request Dialog", by using the preferred type and/or creator set in the
preferences and for modifying the preferences before changing. You can
also instruct it to ignore during its performance, some kind of files or
to treat only some other specific types.
FileT&C is Macintosh Drag and Drop aware, Appearance savvy and requires at
least System 7 to run.
Author: Rocco Moliterno
mailto:[email protected]
http://yellowsoft.home.ml.org/
http://yellowsoft.home.ml.org/filetandc.html
New since version 2.1.0:
Unique FAT version. Appearance savvy. Optimized Drag Manager support.
Improved Modal Dialog filters. Better break keys management. Notification
Manager support. Added "Open preferences" hot key. Moved preferences file
to Yellowsoft folder. Linked with the latest Universal Headers. Linked with
MoreFiles 1.4.8. Linked with Internet Config API 1.4. Removed custom
CDEFs. Fixed a bug occurring only on 68k. Circumvented a System Seven's
Standard File bug. Updated e-mail address. Updated web page address. Many
minor changes.
