MacSentry 1.0.1 - Simple Password Protection
Download: http://archive.info-mac.org/disk/mac-sentry-101.hqx
MacSentry is an elegant and easy to use password protection utility that
prevents unwanted users from gaining access to your computer. It works by
hiding the desktop and all other applications and presenting a dialog box on
the screen that requires a valid password to be entered before access is
returned.
MacSentry is also fully compatible with Mac OS 8's Appearance Manager, which
means you get a consistent user interface as well as the ability to switch
themes.
New in this version:
-The password field now shows bullet characters as the password is typed.
-Fixed the "SpeechLib not found" bug.
-Fixed false access attempt warnings.
MacSentry requires Mac OS 8 or higher.
MacSentry is also available from the Point-Blank web site at:
http://www.pointblanksoftware.com/
