The Complete Disk Space Calculation Solution, features:
* Multi-threaded
* Calculates disk space usage for HFS and HFS+
* Automatically determines the block size for HFS+ calculations
* Optionally can use 512 byte blocks for HFS+ calculations
* Select multiple disks to calculate with one menu option
* Very easy-to-use graphical interface
* Displays relative disk usage
* Calculates disk savings both in size and percent
$15 shareware
