Disk configuration and file management utilities and info. RAM disk, image mount, disk analysis & repair, scsi management, disk copying, file cataloging, directory search, file concatenation, file save & recovery, file comparison & update, alias & trash management. Folder locking, file shredding. (For compression and encryption utilities, see
Compress-Translate. For utilities that work only on text files, see
Text.)
- Administrator
PathKey 1.0
Post
by Info-Mac » October 26th, 1996, 9:00 am
Download:
http://archive.info-mac.org/disk/path-key-10.hqx
This FKEY allows you to use the standard file dialog to find a file and
place its full pathname on the clipboard. Having the pathname on the
clipboard, you can paste it into MPW, scripting tools, etc. Because
it's an FKEY, it can be used from within the tool of your choice.
