Japanese V&N EDICT 1.2 - foreign language learning
Download: http://archive.info-mac.org/edu/lang/ja ... ict-12.hqx
'Japanese EDICT 1.2' is a dictionary module (simple-dictionary) for use
with the 'Verbs & Nouns' and 'V&N Lookup' programs. You can download the
latest versions of 'Verbs & Nouns' and 'V&N Lookup' from the Info-Mac
mirror sites. They are stored in the directory: info-mac/edu/lang.
The original source for this dictionary comes from the Jim Breen's Japanese
EDICT project. Please see
for further details about the Jim Breen's project.
The first port of the Japanese EDICT to the format suitable for use with
'Verbs & Nouns' has been prepared by Michael Fahey in 1999. I've just
converted the Michael Fahey's port to take the advantage of the recent
improvements in 'Verbs & Nouns'.
The dictionary module itself is free, to use it you need the shareware
program 'Verbs & Nouns 2.5.6' or later (or 'V&N Lookup 1.4.7' or later)
which you can download from the same places as this module - the
unregistered versions of 'Verbs & Nouns' and 'V&N Lookup' have some
limitations.
Jacek Iwanski.
