V&N Moby Thesaurus AC - foreign language learning
Download: http://archive.info-mac.org/edu/lang/vn ... -ac-10.hqx
'V&N Moby Thesaurus AC' is a dictionary module (simple-dictionary) for use
with the 'Verbs & Nouns' and 'V&N Lookup' programs. You can download the
latest versions of 'Verbs & Nouns' and 'V&N Lookup' directly from the
Info-Mac archives (the Education/Language directory), or via links from
this web site site: .
'V&N Moby Thesaurus AC' contains the first part (letters A to C) of "Moby
Thesaurus II by Grady Ward".
The dictionary module itself is free, to use it you need the shareware
program 'Verbs & Nouns 2.5.9' or later (or 'V&N Lookup 1.4.7' or later)
which you can download from the same places as this module - the
unregistered versions of 'Verbs & Nouns' and 'V&N Lookup' have some
limitations.
Jacek Iwanski.
