V&N Spanish Phrases - foreign language learning
Download: http://archive.info-mac.org/edu/lang/vn ... ses-10.hqx
Status: RO
'V&N Spanish Phrases' is a sample collection of sentences for use with
Spanish Inflection dictionaries (created with the Verbs & Nouns
language-learning program). This package is an easy way to try out the
'Phrase Engine' feature in 'Verbs & Nouns'. You can easily extend this
module by adding more text-files to it.
To try out the module you should:
1. Make sure that the program Verbs & Nouns version 2.6 or later is
installed on your Hard Disk.
2. Download any of the following 'Verbs & Nouns' Inflection Dictionaries:
- Spanish Verbs (Verbos en Espa?l),
- Spanish Nouns.
You can download any of these direct from the Info-Mac archives (the
Education/Language directory), or via links from this web site site:
. If you are downloading
especially in order to try the Phrase Engine, we recommend 'Spanish Verbs'
(Verbos en Espa?l). If you already have other Spanish Inflection
Dictionaries you can use them instead.
Jacek Iwanski.
