TrueKeys v3.2 release
Programs for manipulating fonts. Font info.
Download: http://archive.info-mac.org/font/util/truekeys-32.hqx
TrueKeys is a Chinese, Japanese, Korean (CJK) 2-byte truetype font conversion
utilities. What makes it different from other truetype utilities such as
TTConvert 1.5 and TrueConvert 0.3b is that it generates its own cmap table for
specified language encoding, and assemble the original font data into a new
truetype. This strategy corrects some common PC font problems such as no Mac cmap
table support, etc. When TTConvert or TrueConvert does not work for your font,
you should seriously try TrueKeys. TrueKeys v3.2 is guarenteed to work with any
Mac format CJK truetypes and Windows format truetypes (including TTC format).
Key Benefits
Convert Chinese/Japanese/Korean truetype fonts between
Windows/Macintosh format.
Add Apple Unicode encoding table to existing font to
support's Apple's Unicode imaging
technology.
popular encodings.
GB2312 (used in Chinese PWindows 3.1/95/98,
Macintosh) Big5 (used in Chinese
CWindows 3.1/95/98, Macintosh)
GBK(used in Chinese PWindows 95/98, Macintosh)
Unicode 2.0 (used in Windows
NT)
Big5 (used in Chinese CWindows 3.1/95/98, Macintosh)
Windows NT)
Shift-JIS (used in Japanese Windows 3.1/95/98,
Macintosh) Unicode 2.0 (used in
Windows NT)
KSC5601 (used in Korean Windows 3.1/95/98,
Windows NT)
System Requirement
MacOS and compatible personal computers with 68030 or better.
PowerPC is strongly
recommended.
System 7.1 or later, MacOS 7.5.3 recommended.
Minimum 8 MB RAM, 16 MB recommended.
Minimum 8 MB free storage on hard drive.
