Word Find v1.5
Interactive entertainment and time killers of all kinds.
Word Find v1.5
Download: http://archive.info-mac.org/game/word-find-15.hqx
Word Find is a program that creates word find (aka word search) puzzles. It
allows words to be entered directly into the program or imported from a text
file.
Word Find allows the user to customize the puzzle by selecting the size of the
puzzle, the font to be used, the directions the words can be hidden in, and the
size of font. The method that is used to hide the words in the puzzle can also be
selected to create a puzzle where the words are as interconnected as possible or
sparsely interconnected.
Word Find also allows the user to select which characters are to be used in the
puzzle. Any ASCII character can be selected as valid. This allows the user to
make puzzles using non-English fonts, or puzzles using symbols or numbers.
Word Find provides capabilities to print the puzzle or save it to a file. Files
created by Word Find are text files that can be directly imported into any word
processor. The puzzle image can also be copied as a PICT image, to be pasted into
another word processor or drawing program. Printing options include the ability
to put a title on the puzzle and/or print a field for filling in a person's name
(particularly useful for Teachers).
Version 1.5 now features:
- Support for Drag & Drop
- Support for the Appearance Manager when drawing the progress bar while
hiding words
- Uses only letters entered in the words when the "Use for filling unused
spaces" preferences option is not selected
- Minor changes to the splash screen and "About..." screens
- Some bug fixes
Version 1.5 is now a fat binary.
Requires System 7.
FREEWARE
Author: Brett C. Helbig ([email protected])
Brett Helbig
Systems Engineer
GORCA Technologies, Inc.
