HAX1R3.HQX - A scenario for Realmz
Download: http://archive.info-mac.org/game/adv/rlmz/hax-13.hqx
Welcome to Hax, a scenario for Realmz! ©1999,2000 John Rawlins
Hax is a role playing adventure scenario for the popular Macintosh
shareware game Realmz. You have come to the Madwood in search of the
elusive town of Hax. It is said the town is overflowing with precious gems
that impart tremendous powers. Many a brave soul has sought to open a trade
route to Hax. Will you dare find success, where they found naught but an
unmarked grave?
Version 1.3 fixes several monolithic bugs.
Hax 1.3 has been built to run with Realmz version 7.0.9. You may have
differing degrees of success if you run this scenario on a different
version of Realmz.
System requirements for Hax are exactly the same as Realmz system
requirements, to wit:
Realmz requires a Macintosh capable of at least 256 Colors, 5 Meg free RAM
minimum and a display capable of 640 x 480 resolution or better. It does
NOT work with the old Apple 12" monitors or some laptop monitors that have
a display resolution less than 640 x 480 in size.
You will also need 800K of hard disk space for temporary files during game
play. This space will be returned to you when you quit Realmz. If you
encounter an error during the start of a new game, check to make sure you
have at least 800K of hard disk space free. Each saved game will also
require from 300 - 800K of hard drive space depending on the size of the
scenario.
Hax costs $10 to register. You can play about half the game for free, then
you need to register if you want to continue.
Hax can only be played on registered copies of Realmz.
PS - It's fine to include Hax on the Info-Mac CD-ROMs.
John Rawlins
