The following file will patch Rebel Assault for the Mac. You will now have the
"Yoda Power Mode" in the option screen. When activated, you can start at any l
level (from 1 to 16) by pressing keys 1-9 and A-F. You can also reduce your
damage points by hitting the "+" key.
