epsConverter 1.4.1
epsConverter 1.4.1
Download: http://archive.info-mac.org/gst/grf/eps-converter.hqx
About epsConverter(tm)
epsConverter is an award-winning Macintosh application from Art Age
Software. epsConverter can read any portable Level 1 EPS file and convert it
into an Adobe Illustrator file, suitable for editing with Adobe Illustrator,
Macromedia FreeHand, Deneba Canvas or any other application that supports
the Illustrator file format.
epsConverter is great for editing EPS files from FreeHand, XPress,
PageMaker, etc. You can also use it to convert EPS files into a format
which Photoshop will import and rasterize (with patterns intact!). The
documentation lists many other uses.
Finally, an economical solution to the problem of incompatible and
non-editable EPS file formats! Try it - you won't be disappointed.
System Requirements
epsConverter requires a Macintosh computer with a 68020 or later processor
(including PowerPC) running System 7.0 or later. Once registered,
epsConverter is accelerated for Power Macintosh computers.
To install epsConverter, simply double-click the epsConverter Installer
icon, and follow the on-screen instructions.
Pricing and registration details can be found in the package.
Version 1.4.1 Changes
* Updated web site and email address
* Default memory partition has been increased to allow use under MacOS 8.5
and later.
