GXMask 1.0.1J - Japanese Version
Download: http://archive.info-mac.org/gst/grf/gxmask-101-jp.hqx
This is the Japanese version of the GXMask package.
Some applications need the GXGraphics Extension installed
in order to function correctly. Other applications (a few Desktop
Publishing packages are the most common offenders) refuse to run if this
extension is installed. This used to mean that you'd have to reboot your
Mac to switch between applications, which isn't very friendly behavior.
GXMask is a Control Panel which lets you hide the existance of the
GXGraphics Extension from all applications other than ones you select (a
list of applications which are known to need GXGraphics is included).
This allows you to have GXGraphics installed, and happily use
applications which would normally refuse to run with it installed. In
all the cases I've tested, this has proven safe, since those
applications don't call GXGraphics, so the fact that it's installed
would have little effect on them anyhow. Do Not use GXMask with the full
QuickDraw GX installation. It will keep GXPrinting from functioning
correctly. GXMask is only intended for use with GXGraphics 1.1.6 or
later.
