MergePICTs
MergePICTs
Download: http://archive.info-mac.org/gst/grf/merge-picts.hqx
MergePICTs is a simple utility that combines the hundreds of PICT files that
some 3D renderers export into a single PICT and mask for use with Sprite
Animation Toolkit (http://www.lysator.liu.se/~ingemar/sat.html).
This tool was programmed for my own puposes and to help ease my insanity
with Ray Dream's lack of file formats. It requires that all the images
be PICTs and that the file names look like this: blahblah01 blahblah02
blahblah03 etc. Of course instead of blahblah you have some "descriptive"
name.
If you dislike either of these requirements than you are free to modify it,
the download includes source code. If you make any good improvements to it
though I'd appreciate it if you'd send them to me. Enjoy! You will need
to have TransSkel (http://www.primate.wisc.edu/software/mac/TransSkel/) to
compile any changes you make to it!
-Ian Levesque
http://www.kagi.com/ephemeron/
