PhotoStickies 5.4
PhotoStickies 5.4
Download: http://archive.info-mac.org/gst/grf/pho ... ies-54.hqx
Use this program to stick multiple photos (located on your local drives
or in the Internet) to your screen, as a fast image viewer, for webcam
viewing, recording & replaying, to display slideshows (with sound), as
a wallpaper utility (e.g. view pictures of day/hour or periodically
rotate through all images of a folder) or just as an advanced
XTeddy-clone.
Key features:
- Windows are borderless ("Stickies")
- Windows can float above all or behind all windows
- Supports and even calculates alpha channels and therefore your
stickies don't have to be opaque rectangles
- Records and replays webcams
- Supports fading, transparency and shadows
- Zooms, tiles, rotates and flips images
- Saves and restores multiple window states
- Favorites to access your preferred images easily
- Supports multiple screens
- Is highly multi-threaded and dual processor optimized
What's unique:
- Runs as a menu extra or as an application
- Possibility to click right through images ("Overlay Windows")
- Loads recently posted cams on startup and can post new ones too
- Special webcam mode to save your bandwidth for other tasks or
monitoring lots of webcams at the same time
- Realtime filtering of images, webcams and slideshows (e.g. blur,
sharpen, contrast, brightness, edges etc.) to improve display quality
- User-defined matrix filters
- Displays slideshows and replays webcams with sound
- Minimized webcam and slideshow windows are updated and support fading
- Saves (filtered) images as TIFF, BMP, GIF, PNG or JPEG files or
copies them to the clipboard
License: Shareware (US $12)
System Requirements: Mac OS X 10.2 or higher
Info:
http://www.devon-technologies.com/produ ... reware.php
http://www.devon-technologies.com/files ... shareware/
Download: 887 KB, 907916 bytes
http://www.devon-technologies.com/downl ... reware.php
http://dl.filekicker.com/send/file/1545 ... ies.dmg.gz
http://www.devon-technologies.com/files ... ies.dmg.gz
