PixxxSafe 1.6
PixxxSafe 1.6
Download: http://archive.info-mac.org/gst/grf/pixxx-safe-16.hqx
PixxxSafe secures your images using state of the art AES encryption. The
first time the software is launched, you will personalize your copy of
PixxxSafe, so that only you can access your encrypted files.
Choose your user name and password carefully. Use 8 or more random
alphanumerical characters. Memorize them or keep them in a safe place.
PixxxSafe uses this password to generate a unique key, and uses this key to
manage access to your protected files. Your password itself is never saved
to the hard drive, so there is no way to retrieve it.
Key features
* Import picture series and group them in password protected ".pxs" fles.
* Encrypt your pictures with AES 256 bit encryption.
* Create slide shows.
* Export and archive your encrypted image series.
* Integration with PixxxGrabber allows easy batch download of images
directly to your PixxxSafe library.
Installation
Drag the PixxxSafe icon to your Applications folder.
Double-click it to start.
Licensing information
PixxxSafe is shareware. There is a 30 day evaluation period, after which you
are required to enter a valid license key.
A single user license costs US$ 15.
Changes:
- Improved integration with PixxxGrabber 1.3.
- Added version checking.
- Added new Help documentation.
- Added startup tips.
- Several minor bug fixes.
