ReduceNoise.sea.hqx - A PhotoShop plug in for PPC Mac
Download: http://archive.info-mac.org/gst/grf/psh ... -noise.hqx
Reduce Noise is a plug in for Adobe Photoshop. It requires Photoshop
4.01 for PowerMac. The plug in works on Filmstrip files (only) so it is
probably of no use to anyone without Adobe Premiere. The plug in is
primarily intended to clean up still images captured on video. You
capture multiple, identical frames, with your video device. Then you
save your movie as a Filmstrip and open it in Photoshop. Then you can
use the plug in to average all the frames together to clean up video
noise. This is version 0.4. It is Freeware.
There is more information on the following web page:
