AsktheDJ1.3.sit, a revolutionary DJ/mix engine
Download: http://archive.info-mac.org/gst/snd/ask-the-dj-13.hqx
Ask the DJ is a sophisticated mix engine which analyses the music's rhythm
to perform DJ-like transitions between tracks... automatically!
Ask the DJ will also:
search your music library
- optimize your play-list
- skip intros and outros
- level the volume
- export mixes to audio files
Version 1.3 handles AAC protected (".m4p") files from the Music Store and
can index FAT (MS-DOS) volumes, such as iPods. It also fixes problems with
version 1.2.
Ask the DJ is shareware and costs $29. Until you register, it stops every
minutes and you can't save play-lists or export to audio files.
Requires Mac OS X v10.0 or later.
Copyright 2003, Sylvain Demongeot
Ask the DJ may be transmitted freely between individuals. Ask the DJ may be
incorporated in a shareware archive (CD-ROM or online) in the form of the
original archive, provided the author is informed of such distribution. If
Ask the DJ is distributed through a hardware medium (e.g. magazine with
CD-ROM), it would be appreciated (but not required) that the author receive
a copy of the medium. Ask the DJ may not be distributed for any other
purpose without the author=B9s permission.
Contacting the Author:
Please write to Sylvain Demongeot .
http://www.wildbits.com/askthedj/
