gURLfriend v1.02
gURLfriend v1.02
Download: http://archive.info-mac.org/inet/g-url- ... pc-102.hqx
gURLfriend is a utility that will parse your Netscape or Internet
Explorer bookmarks files into a format that is more convenient to post
onto a web site. The standard bookmark file contains information such
as the add date, the last visit and the last modified time. This extra
information is pretty much useless to most people and is removed by
gURLfriend. The gURLfriend application also searches through your
bookmarks list and indexes all the bookmark folder names and creates a
table of contents. This table of contents appears above the list of URLs
when viewed using a browser. By clicking on the folder name, the user is
brought to the place in the URL list that contains those links.
How do I use gURLfriend?
gURLfriend is very easy to use. Simply drag and drop your bookmarks
file onto the gURLfriend application. gURLfriend will write out a file
named gURLfriend.html. Your original bookmarks file is untouched. You
can then post this HTML file onto your web page.
Why would I want to use gURLfriend?
If you are like me you put a copy of your bookmarks list on your home
page. By using gURLfriend you will significantly decrease the size of
this file and also make it easier to use. My bookmarks file size went
from 64K to 35K after running them through gURLfriend. It is also
indexed which makes it easier to use. A parsed bookmarks file takes much
less time to transfer when posted on your page.
Where can I find updates to this program and other software by the
author?
Check out the following URL for my shareware page:
http://www.best.com/~jluszcz/software.html
