URLstory 1.7 PPC
URLstory 1.7 PPC
Download: http://archive.info-mac.org/inet/url-story-17-ppc.hqx
URLstory 1.7
URLstory is an application to keep a record of the sites you visit with
Netscape. There are a couple other progams that do this, but they all did
more than I wanted. I just wanted a simple app that would keep track of the
pages I visited, and save the links as an HTML file.
URLstory is $5 shareware. There are no nag screens, timeouts, or hidden
features, registering is just a way to show your appreciation and support
future development and releases. You can register via the Kagi service,
using the included Register application.
NEW IN 1.7:
* On/Off Control
* Non-modal Exclusion List Window
* Plain text files will now be added to URLstory's list as well as HTML
files.
URLstory only works with Netscape Navigator (version 3.0 and up); Internet
Explorer has a history feature built in.
URLstory should work on just about any Mac running System 7 or above. Both
68k and PPC versions are available.
URLstory requires AppleScript, which comes with the MacOS, or can be
downloaded from http://www.apple.com/
URLstory is shareware, I retain the copyright, and am not responsible for
any losses or damages you incur through using URLstory.
URLstory may be freely distributed, provided that this Read Me file, and
the Register application are included. URLstory may be included on the
Info-Mac CD-ROM.
