PageSpinner 2.0.1
PageSpinner 2.0.1
Download: http://archive.info-mac.org/inet/html/p ... er-201.hqx
PageSpinner 2 is an HTML editor for MacOS that supports HTML 2.0, most
parts of HTML 3.2 plus additional Netscape and Explorer extensions and is
useful for both the beginner and the more advanced Web author. The editor
gives you quick access to often used formatting and also supports
interactive help with AppleGuide and an HTML Assistant to help you compose
your Web pages.
PageSpinner is scriptable with AppleScript, making it possible to take a
script-driven approach to creating and updating a site. Included are
several scripts that automates tasks and kits for publishing data from
popular database applications or from plain text files. Support for
extension plug-ins allows users to download new or updated functions and
examples from the net. PageSpinner also includes support for the latest Web
technologies such as: Cascading Style Sheets, Browser plug-ins, Frames,
Java and JavaScript.
The editor also supports include files that makes it possible to change
common sections in a group of pages by editing a single include file and
running a script.
Included in the distribution are also additional utilities, examples and
plug-ins for using other applications. All menus can also be displayed as
floating menu palettes, giving Web developers an easy to use interface with
single click access to all functions offered by menus, extensions and
scripts.
More information about PageSpinner can be found at:
http://www.algonet.se/~optima/pagespinner.html
PageSpinner is shareware, US$25.
Have fun,
Jerry Aman
Optima System
