eMerge 1.6.5 -- Customerize your e-mail
Download: http://archive.info-mac.org/inet/mail/emerge-165.hqx
Galleon Software has just put the final touches on version 1.6.5 of
eMerge, our dead-easy, Mac-only, e-mail merge application. This release
fixes problems found in earlier versions and introduces some new
features and improvements described below.
http://www.galleon.com/emerge
With this new version of eMerge, we have laid the groundwork for the
long-awaited jump to eMerge 2.0. We are currently testing an
AppleScriptable version of eMerge 1.6.5 and are looking for customers
who are interested in using this to automate common eMerge tasks. If you
are interested in joining this program, please send a message to [email protected].
Regards,
Roy Schulze
Galleon Software
New features and changes in version 1.6.5
-- You can now import contact information from Palm Desktop exports.
-- The new Export Selected option in the Export dialog allows you to
export just those records you’ve selected in your mailing list,
including discontinuous selections.
-- For each of your campaigns, eMerge now remembers the field order you
used when you last imported data to that campaign.
-- You can now use the variable menus to insert a variable into the
message header fields.
-- eMerge now allows you to import the message Status field.
-- Clicking Substitute Variable Names during an import now correctly
assigns those names to the Custom Variable menu.
-- Variable names used within variables are no longer case sensitive.
