, Date
, Date
Download: http://archive.info-mac.org/inet/mail/e ... -12-hc.hqx
ETD v1.2 is a HyperCard stack that reads Eudora mailboxes (don't worry, it
only reads them, causing no damage!), and formats the messages into a file
suitable for importing into a database or spreadsheet. I've included a
template for FileMaker Pro®. The following information is parsed out, in
this order: Mailbox Name:, From (Name):, From (e-mail):, To: & Cc:,
original message text. Having your mail in a database makes it much easier
to summarize, report on, and use. If you need to use the power of a
database on your e-mail, give ETD a try.
Version 1.2 adds the ability to translate your message using either the
standard Mac ASCII character set or the ISO Latin 1 set, making ETD much
more friendly for my West European users.
