Web Finder V3.0 - Simplify Internet searching
Download: http://archive.info-mac.org/inet/web/web-finder-3.hqx
Web Finder is a utility that uses Internet search engines to find anything you
like on the net, giving you your result in the front most window of your favorite
Web browser. With little or no effort you can search the net on the fly getting
results in about a quater of the time it would take with the normal hassling
approach.
Web Finder currently ships with the following Internet topic search engines:
*World Wide Web
*News
*UseNet
*Macintosh File Archives
*MPEG layer 3
And with the new Web Finder Factory you can add other search engines to Web Finder quickly and easily.
System Requirements:
*Apple script 1.1.2 or later. It comes with MacOS 8.0 and later. So if you have OS 8 be fine. If not you can download it from a site linked to Apple's Applescript page.
*A MacOS compatible computer. Preferably running MacOS 8 or later. Web Finder has only been tested on MacOS 8 and up. It is unknown whether it will work on earlier system versions.
Scripting Additions:
*The 'Internet scripting', 'File Commands', 'Display Dialog', and 'Dialog Director V0.6' scripting additions must be installed in the Scripting additions folder inside your system folder. The first three are part of Applescript 1.1.2 and are installed under MacOS 8, Dialog Director comes with Web Finder.
*Approx. 750kb of disk space.
*400kb of Free RAM. 600kb Recommended.
