Download: http://archive.info-mac.org/nwt/dev/newt-33.hqx
Newt 3.3 (24 Nov 96):
an environment for developing applications using NewtonScript
and saving as packages directly on your Newton.
Keywords: object-oriented programming, application development
environment, NewtonScript, NTK.
Summary of changes in Newt 3.3:
- added info button and updated about box (URLs are active if
Newt's Cape is installed); added protoAboutText and protoInfoButton
protos. (see updated NewtATut example).
- Prefs view (via "i" button) allows customization
- Select Library allows selection of Workspaces of Personal Media documents
- many updated/new examples, including some that use Newton Internet
Enabler (NIE)
- compatible with 1.x and 2.0 Newtons (and 2.1: MessagePad2000 and eMate300)
Newt is shareware -- registered users can download (or receive floppies with)
additional versions, 200+ examples, plugins, tools, documentation.
Steve Weyer
Internet: [email protected]
[email protected], [email protected]
America Online: SteveWeyer
Compuserve: 74603,2051
http://www.netaxs.com/~weyer/newton/releases.html
