logo-sender-119.hqx Sending logos, SMS and ringtones to Nokia mobile phones.
Inter-computer communication software: Modem dialers, file transfer, telecommunications, etc.
Download: http://archive.info-mac.org/comm/logo-sender-119.hqx
LogoSender 1.1.9
for Nokia 7110, 7190, 7210, 7250, 6100, 6210, 6250, 6310, 6310i, 6510,
6610, 8210, 8290, 8310, 8390, 8810, 8850, 8890, 8910, 8910i
(Mac OS X version available at http://www.macmedia.sk/logosenderX.sit)
- sending operator logo, caller group graphic, picture SMS, text SMS
and ringing tones to another (or your own) Nokia mobile phone from the
phone connected to your computer through the GSM network
- bigger operator logos (78 x 21 pixels, for Nokia 71xx, 62xx) are
supported
- standard logos (72 x 14 pixels, for other Nokia phones) are supported
- caller group graphic (72 x 14 pixels, for almost all Nokias)
- picture SMS (72 x 28 pixels for almost all Nokias)
- simple graphic editor, import picture from a file
- download phonebook from the phone
- saving phonebook to the file
- phonebook export as tab-separated text
- phonebook export as vCards
- phonebook printing
- phonebook editing (extended phonebook is not supported)
A picture of required size and black&white bitmap format may be
prepared in a built-in simple editor, or in a standard graphic editor
(GraphicConverter, Adobe Photoshop or similar) or downloaded from the
Internet and then opened in LogoSender. After entering the recipient
phone number the connected mobile phone will send the logo, SMS or
ringing tones through the GSM network. Standard phonebooks can be
imported from the phone and saved to a file.
Graphics and ringing tones can be sent to Nokia phones only, text
messages can be sent to any phone.
Requirements:
MacOS 8.6 - 9.x
Serial, USB or Infrared connection to the phone
Shareware $19.95
MacMedia
www.macmedia.sk
