Lines&Kinetics
Lines&Kinetics
Download: http://archive.info-mac.org/sci/lines-kinetics-10.hqx
Application Lines&Kinetics
Version 1.0
Update Mars 98
Author M.G. Claros
Literature Embnet.News 5, 7-9
Disk size 125 Kb
RAM Size The minimum requested by HyperCard
Description A graphic way to calculate linear regressions with normal
or logarithmic data, the doubling time of a microbial
culture,
and the kinetic parameters for an enzyme reaction.
Notes Lines&Kinetics is a HyperCard Stack programmed in HyperTalk.
It requires HyperCard (Player) 2.1 or later and the Home
stack provided with Lines&Kinetics.
The describing article is include in the Home stack that
accompanies the program stack. Is is also available at
http://www.ie.embnet.org/embnet.news/vo ... etics.html
Although I have done my best to ensure that this software is error free,
I am not responsible for any misfortune you may suffer whatsoever caused
through the use of Lines&Kinetics, being they incidental, consequential or
otherwise. So, Lines&Kinetics is supplied "as is": it comes without any
warranties, express or implied, of any kind, including fitness for
purpose and merchantibility. You may find some bugs too, or things
lacking which should be included. If you have comments, I would like to
know them, but I do not assure to be able to fix them. You can distribute
this software freely.
Dr. Manuel G. CLAROS [email protected]
Dpt. Bioquimica y Biologia Molecular [email protected]
Facultad de Ciencias Fax: (34 5) 213 20 00
Universidad de Malaga
E-29071 Malaga (Spain)
