Math/Statistics Program
Download: http://archive.info-mac.org/sci/regression-21.hqx
Regression 2.1 is an easy-to-use regression analysis program. Data sets can
be fitted to linear, logarithmic, exponential, or power equations.
Regression 2.1 also computes the relative strength of each fit. Using the
model predicted, the check feature will return values of x or y based on
the equation. Unlike expensive statistical analysis programs, Regression
has a simple, easy-to-use interface, meaning you won't have to spend hours
in front of a complex manual.
Regression was originally a product of BattleAxe Software, which merged
with Enterprise Software in May 1998 to form TriVectus.
Version 2.1 reflects the change to TriVectus ownership, and makes numerous
improvements internally, cleans up the interface a bit, and moves the
entire code base to the PowerPC processor.
Requirements:
* Mac OS 8 or higher
* PowerPC processor
Regression is shareware, priced at $15 for a single-user license.
For more information, visit our web site or e-mail us.
TriVectus
http://www.trivectus.com/
mailto:[email protected]
