Tex-Edit Plus for OS X 4.4.1b2J - Japanese Version
Download: http://archive.info-mac.org/text/texedi ... 1b2-jp.hqx
This is the Japanese version of the Tex-Edit Plus package.
Tex-Edit Plus is a scriptable, styled text editor that fills the gap
between Apple's bare-bones SimpleText and a full-featured word
processor. It's fast, efficient, and has a clean, uncluttered interface.
It's also great for cleaning up text which is transmitted over the
Internet.
Tex-Edit Plus features: Extensive munging abilities, unlimited file size,
Drag&Drop support, AppleScript support, Word Services support,
Speech Manager support, picture handling, sound handling, movie handling,
ability to create SimpleText Read-Only documents, unlimited undo and redo,
and much more.
Tex-Edit Plus can read and write UTF-16 (unicode) text and RTF files.
Each paragraph can be formatted individually. These new paragraph
settings include text justification (left, center, right, full), space
above, space below, left indent, right indent, first line indent (or
hanging outdent), and bottom border (in one of several line styles).
Each paragraph can also have its own line spacing (in one point
increments) and dominant text direction (useful for right-to-left
scripts).
Version 4.4.1b2:
* Improved handling of irregular RTF files.
* Fixed bug that sometimes mounted offline volumes automatically if they contained
previously-opened documents.
* Launches faster (in OS 10.2.x).
* Horizontal scrolling with scroll wheel now supported. (Hold down the shift key.)
Version 4.4:
* Spell checking added.
* Hold down the option key to check the spelling of the current text selection.
* Added support for system Fonts Panel (requires OS 10.2 or greater).
* Drag and drop desktop files onto document windows to insert text.
* Option-return overrides the "Auto Indent" feature.
* Faster application launch when Scripts folder is large.
* Removed the limitation on font size.
* Added "tell selection" shortcut to Quick Script dialog.
* Fixed Jaguar printing bug involving certain unusual configurations.
* Fixed Scripts menu bug that prevented use of scripts created by the new
Jaguar version of Script Editor.
* Fixed bug involving sound playback on systems without sound capability.
