Text ta' See
Text ta' See
Download: http://archive.info-mac.org/text/text-ta-see-20.hqx
Text ta' See - is a text searching program that can search text files for up to 8 different words/phrases at a time. Once located Text ta' See arranges files found in descending order by the number of matches each file had and reports the full path to the file plus other pertinent information ie, creator, size, date modified and date created. Text ta' See will also display snippets of text showing the context in which the search string was used. To further narrow the search Text ta' See allows one to search the found set of files by a new set of words/phrases.
