TextLock 1.0; [TEXT->ttro]
Download: http://archive.info-mac.org/text/textlock-10.hqx
Are you tired of opening ResEdit or any other file editor program just to
change a SimpleText document's file type to read-only? Or do you want to be
able to copy text from a read-only SimpleText document, only to find that
you can't select any text? Do you simply want to distribute a document in
read-only format, yet don't know how to go about doing so? TextLock will do
it all! It will convert SimpleText documents to and from read-only format,
convert text documents created with other programs to SimpleText documents,
and is drag-and-droppable!
For those familiar with file types, TextLock simply changes documents with a
file type of 'TEXT' to 'ttro', and documents with a file type of 'ttro' to
'TEXT'.
Evan Scarisbrick
Xenix Software
http://home.earthlink.net/~xenix/sw/
