Yellow Extensions Toolkit 1.0
Download: http://archive.info-mac.org/text/yellow ... oolkit.hqx
Yellow Extensions Toolkit allows you to write extensions used by YellowEdit
and other applications supporting this kind of extension. The project
example is for CodeWarrior Pro 3. Inside its sources you may find all
explaining notes you want.
Author: Rocco Moliterno
mailto:[email protected]
http://yellowsoft.home.ml.org/
