BBEdit/GetURL Pro 1.0
Download: http://archive.info-mac.org/text/bbe/ge ... bbedit.hqx
To install the "GetURL Pro" extension, place it into your "BBEdit
Extensions" folder and restart (or launch) BBEdit. "GetURL" will appear now
in the BBEdit's "Extensions" menu.
GetURL Pro 1.0
"Uniform Resource Locators" (URLs) are standard notation on the Internet
for identifying the locations of files and various other resources.
To use the "GetURL Pro" extension, select a portion of text containing a
URL, then choose "GetURL" from the "Extensions" menu.
You'll be asked to select an application (or helper) to open the URL.
The application will be launched (or switched to, if currently running) and
the URL (if valid) will be opened.
"GetURL Pro" remembers which helper program you've selected last, so you
need to select an application only once. However, if you wish to change the
helper program to a different one, simply choose "Get URL" from the
"Extensions" menu while holding the "option" key down.
You can also use the "Set Keys..." option in the "Extensions" menu to
assign extension keys to "GetURL" so that any URL is just a short keystroke
away.
"GetURL Pro" requires System 7 and relies on the standard Apple event suite
for Uniform Resource Locators which is now supported by most Macintosh
TCP/IP networking programs (e.g.: Anarchie, Mosaic Netscape, NewsWatcher,
MacWeb, etc.)
"GetURL Pro" is free. There is no shareware fee.
Enjoy!
Raven Systems Ltd.
February 1, 1995
This version of "GetURL Pro" was designed and developed by Erik C. Thauvin
using Symantec's THINK C development environment for the Macintosh.
Raven Systems Ltd. makes no warranty or representation, either express or
implied, with respect to this software, its merchantability, performance,
quality, or fitness for a particular purpose. As a result this software is
distributed "as is", and the person using it is assuming the entire risk as
to its quality and performance.
In no event Raven Systems Ltd. will be liable for direct, indirect,
special, incidental, or consequential damages resulting from any defect in
the software or its documentation, even if advised of the possibility of
such damages. Raven Systems Ltd. does not warrant that this software will
function correctly in your multi-user environment.
Raven Systems and the Raven Systems logo are trademarks of Raven Systems
Ltd. All other products and company names are trademarks or registered
trademarks of their respective companies.
Copyright (C) 1995, Raven Systems Ltd. Permission is granted to make and
distribute copies of this software, provided this disclaimer and copyright
are preserved on all copies. This software may not, however, be sold or
distributed for profit, or included with other software which is sold or
distributed for profit, without the permission of the author.
Erik C. Thauvin | Custom software solutions | Raven Systems Limited
[email protected] | for everyday problems. | P.O. Box 560862
+1 (206) 747-9819 | | Orlando, FL 32856, USA
(URL) http://www.eskimo.com/~ravensys/ ---- ftp://ftp.eskimo.com/ravensys/
