BBEdit Insert Date/Time 1.2
Download: http://archive.info-mac.org/text/bbe/in ... ime-12.hqx
To install the "Insert Date" and "Insert Time" extensions, place them into
your "BBEdit Extensions" folder and restart (or launch) BBEdit. They will
appear now in the BBEdit's "Extensions" menu.
The "Insert Date" and "Insert Time" extensions perform simple but useful
functions. When activated, they insert the current date and time at the
cursor's location.
Insert Date v1.2
To use the "Insert Date" extension, select it from the "Extensions" menu
and the date (in its abbreviated format) will be inserted into any open
document.
Example: Mon, Feb 6, 1995.
By holding the "option" key down while selecting "Insert Date", you can
insert the date in long format.
Example: Monday, February 6, 1995.
To insert the date in short format, simply hold the "shift" key down while
selecting "Insert Date".
Example: 02/06/95.
Insert Date Example Modifier Key
Mon, Feb 6, 1995 None
Monday, February 6, 1995 option
02/06/95 shift
Insert Time v1.2
When selected from the "Extensions" menu, "Insert Time" will insert the
time (including seconds) into any open document.
Example: 4:40:05 PM.
To insert the time without seconds, just hold the "option" key down while
selecting it.
Example: 4:40 PM.
(12hr.)
4:10:14 PM None
4:10 PM option
(24hr.)
16:10:14 None
16:10 option
You can also use the "Set KeysŠ" option in the "Extensions" menu to assign
extension keys to "Insert Date" and/or "Insert Time", then a date and time
stamps are just a short keystroke away.
"Insert Date" and "Insert Time" are free. There is no shareware fee.
Enjoy!
Raven Systems Ltd.
February 6, 1995
The "Insert Date" and "Insert Time" extensions were designed and developed
by Erik C. Thauvin using Symantec's THINK C development environment for the
Macintosh.
History:
Version 1.2 adds support for the "Undo" command (BBEdit version 3.0 or
later).
Version 1.1 was the initial release of "Insert Time" bundled with "Insert
Date".
Version 1.0 was the initial release of "Insert Date".
Erik C. Thauvin | Custom software solutions | Raven Systems Limited
[email protected] | for everyday problems. | P.O. Box 560862
+1 (206) 747-9819 | | Orlando, FL 32856, USA
(URL) http://www.eskimo.com/~ravensys/ ---- ftp://ftp.eskimo.com/ravensys/
