FastOpen 3.0; open document quickly
Download: http://archive.info-mac.org/gui/fast-open-30.hqx
FastOpen is a system utility that allows you to open any document
with the application of your choice quickly and instantly from the
contextual menu.
For each file type, FastOpen will let you add a customized list of
applications to use in opening that kind of file. All you need to do
is highlight the file and simply select the application from the
contextual menu. It's that easy.
FastOpen even lets you create application sets to open files whose
names end in ".html", ".hqx", ".bin", ".uu", or any other suffix you like.
News (Version 2.5 -> 3.0):
- If the original application of an alias doesn't existe, send open doc
AppleEvent
- Added Auto Repair feature. You need repair FastOpen settings in case of
the original application of an alias doesn't existe. Now repair can be
done automatically.
- Added Pre-Settings feature. You needn't start at zero to select your
favorite name suffix, document types and applications.
- Added many options in preferences: mark symbol, default applications,
priority, the native application.
- Fixed some minor bugs.
For more information, please read the Readme file enclosed,
or visit my web page:
http://www.kagi.com/guoniu
Guoniu Han
