Finder 8.1 JP Menu Patch v2.1
Download: http://archive.info-mac.org/gui/finder- ... -21-jp.hqx
Finder 8.1 Menu Patch will add cmd-T to the "Empty Trash..." menu item in
the Finder.
Requirements:
- PPC or 68k Macintosh
- MacOS 8.1 (of course)
If you've patched your Finder with an older version of this program then
you should probably download this new version. It adds a much more
practical 'undo' feature than the last version had which doesn't require an
old, untouched copy of the Finder. Some minor code problems have been fixed
as well.
The patch will be applied over any existing "Special" menu patches or
modifications.
This version is for Japanese systems.
