Hide All Apps
Hide All Apps
Download: http://archive.info-mac.org/gui/hide-all-apps.hqx
Here are two AppleScripts that will hide all open applications.
These scripts have been tested on Mac OS 9.2.2 with CarbonLib 1.5.
"Hide All Apps" does exactly what it says, it hides all open applications.
"Hide Apps/Keep Top Folder Open" will hide all open applications and
close all open folders except for the front most folder in the Finder.
You can set these scripts to a Hot Key, put an alias in your Apple Menu or
add them to your Favorites folder.
This is ThankYouWare. If you use them, please send an e-mail to:
Cam Meca
