iClip 2.1 - a multi clipboard/scrapbook utility for Mac OS X
Download: http://archive.info-mac.org/gui/i-clip-21.hqx
Experience the power of clipping bins with this multiple clipboard/scrapbook
iClip is a utility that helps you get past the limitations of having a
single Clipboard. It allows you to quickly copy & paste and drag & drop
clippings to and from its multiple "clipping bins" so that you can easily
access them in the applications you're using. The clippings can be of
various types such as text, pictures, Internet locations, sounds, and more.
Clippings can be organized into unlimited groups called "clipping sets" to
help you keep all of your clippings neatly arranged. Since the Scrapbook
application that was in older Mac OS versions isn't a part of Mac OS X,
iClip can conveniently serve as a replacement for it.
iClip can be used to store and retrieve text, pictures, and other types of
clippings that you commonly use. It can also be very useful for when you're
dealing with multiple clippings between two or more applications. Another
use for iClip is for temporarily storing a bunch of similar clippings,
especially when saving each one to a file would be inconvenient. iClip can
be used in these ways and in many more to help you to be more productive and
efficient.
What's new in version 2.1:
- a dramatic increase in clipping set loading speed
- iClip opens much faster now
- saved clippings now take up much less hard drive space
- improved Unicode support
- ability to change the locations of clipping control buttons (left/right
for vertical orientation, top/bottom for horizontal orientation)
- ability to rearrange the clippings sets order
- various minor bug fixes and enhancements
iClip is available as $19.95 shareware for Mac OS X v10.1 or later.
This file may be freely distributed.
Inventive, Inc.
http://inventive.us
