Launch Pack 1.0 released
Download: http://archive.info-mac.org/gui/launch-pack-10.hqx
Launch Pack 1.0 is a drag & drop utility to create files that launch
multiple documents and applications or opens folders by a simple
double-click. It's very easy and straightforward to use and can also
create aliases or copy files on the fly. It preserves custom icons so
you can give the launchpacks your own look as you like.
Launch Pack is $10 shareware.
Author: Erich H Rast
Requirements: a Macintosh, OS 7.6 or higher (8 recommended), 2 MB RAM
Launch Pack 1.0 is a drag & drop utility to create files that launch multiple documents and applications or opens folders by a simple double-click. It's very easy and straightforward to use and can also create aliases or copy files on the fly. It preserves custom icons so you can give the launchpacks your own look as you like.
