Download: http://archive.info-mac.org/gui/mabasof ... sm-211.hqx
Quit CSM is a control strip module which lets you quit applications
without having to activate them. With Quit CSM you can:
- quit a single application, all background applications and all
running applications;
- quit and restart the Finder;
- quit background-only applications;
- display the largest unused memory block and the memory in use;
- show application sizes;
- enable a hot spot for showing and hiding the Control Strip;
- hide the background applications and show all running applications;
- automatically hide applications on context switch;
- put your computer to sleep, restart it and shut it down.
Quit CSM is 5 US$ shareware.
System Requirements
Control Strip, Extensions Strip (2.0bx or higher) and ACTION GoMac
can be used as module host.
What's new in Quit CSM 2.1.1?
A bug concerning the Sleep command has been fixed. On certain Mac
models supporting sleep mode the possibility of putting the computer
to sleep was not correctly recognized: the Sleep command could not be
added to the Quit menu.
