MyEyes 2.3.5
MyEyes 2.3.5
Download: http://archive.info-mac.org/gui/myeyes-235.hqx
MyEyes 2.3.5 (an update)
What is MyEyes?
MyEyes draws on the menubar a pair of eyes constantly following the cursor
movement.
Using a control panel you can modify almost every aspect of the eyes
(color, position, behaviour).
MyEyes also supports plug-ins (External Eyes Sets), giving users the
opportunity of designing their
own eyes icons and/or use icons made by other people.
System requirements
68020/030/040 or PowerPC;
80 KBytes free memory for the extension;
Mac OS 7.1 or later;
Color QuickDraw.
What's new in MyEyes 2.3.5?
- Fixed a long standing bug in the registration code validation
algorithm that caused the control panel to crash occasionally on 68k
machines.
- Removed any reference to FTP application in the control panel.
Installation
The MyEyes package is distributed in form of an "Installer" application.
To install MyEyes just launch the installer and follow the simple
instructions. It is recommended to restart your computer after installation.
Distribution
MyEyes is 10$ shareware.
You can distribute MyEyes freely, provided that you leave the software and
the accompanying documentation unchanged. You can include MyEyes in CD-ROMs
and other software collections only by previous agreement.
Thanks and best regards.
Federico
