SwitchRes 2.5.3J - Japanese Version
Download: http://archive.info-mac.org/gui/switch-res-253-jp.hqx
This is the Japanese version of the SwitchRes package.
Rated 5 Cows (highest rating) at Tucows!
What's new in this version:
*Corrects two bugs when reloading preferences after a restart when older
settings were not retrieved
*Solved a bug in Display Sets where main display and display position
should be both set together on 2 displays
SwitchRes is a little utility that will allow you to switch the
resolution of all your monitors . You can access to all the resolutions
of all your displays in a simple, customizable menu. SwitchRes
incorporates features from the Monitor Resolution, Monitor BitDepth, and
Video Mirroring Control Strip Modules bundled with your system. You can
use its menu in the Menu Bar, use its provided Control Strip Module, or
click on the Finder Desktop with its Contextual Menu Plugin.
SwitchRes has an extensive list of features:
* You can show and use all available resolutions of your video card,
not just those limited by your monitor. For example, 20 video modes are
available on my PowerMac 7300 internal video board. Enjoy your Apple 15"
monitor in 1024 x 768, or 640 x 480 in 120Hz !
* SwitchRes is totally configurable. You can define which resolutions
are really accessible, and which will require a confirmation.
* You can also create display sets which will allow you to change the
resolution and the depth of all your monitors with just one mouse click,
or just one key. With this new version, you can add scripts to display
sets. That gives SwitchRes the ability to launch a script with just one
key, or when an application is launched...
* You can assign a specific set to an application , so that every time
you use this application, your Mac will automatically switch to your
predefined resolutions. You will find this extremely useful for most
games.
* You can save the position of the icons and the windows on your
desktop, independently from one resolution to the other, unlike the
Finder. The configuration is restored at startup.
* You can script SwitchRes for resolutions and color depth changes.
SwitchRes is even recordable: When SwitchRes is running, every
resolution change is automatically recorded in the script editor
