Cool Blue Deluxe Folder Icon Creator 1.6.1cb
Download: http://archive.info-mac.org/gui/icon/co ... er-ico.hqx
The Cool Blue Deluxe Folder Icon Creator uses the new Cool Blue icon set
posted at the Icon Factory and the very nice Deluxe Folder Icon Creator
utility for creating custom folder icons to allow you to create really
nice looking Cool Blue custom folder icons.
Yes, this is a hack.
Neither the author of Deluxe Folder Icon Creator nor the author of the
Cool Blue Icon Set had anything to do with the release of this little
applet. The DFIC has been modified to use the Cool Blue Icon Set as its
template for creating new folder icons.
However, with a DFIC update not having been released in years and Cool
Blue Icons being as cool as they are, it seems the natural combination.
The Cool Blue folder set works quite well with the DFIC applet to create
custom Cool Blue icons for your desktop! Since the Cool Blue set already
has replacements for all your system folder and standard icons, this
allows you to create customized folders for your other applications
and/or utility sets. Check out some of the examples I have included to
get ideas for your own icons.
I hope you enjoy it, and that it works great for you, but since it is a
hack, you use it at your own risk and no guarantees are made about the
operability of the software. Don't write me or the other authors if it
doesn't work.
Have Fun!
Dave Bailey
PS- The Icon Factory is incredible! (no, they didn't have anything to do
with this applet either, so don't bother them.)
http://www.iconfactory.com/
