Flowchart Maker 1.3 ppc
Download: http://archive.info-mac.org/app/flowchart-maker-ppc.hqx
Flowchart Maker is the amazing Mac only program to realize flowcharts.
Flowchart Maker has a true Mac interface, is easy to use, and has lot of
powerful features. It can realize complex flowcharts and print or save them
for web page usage.
To realize flowcharts user can select the box type he likes from a floating
palette and drag in the document where he needs to place it.
Then he can select lines from the palette and use them to link boxes. Fast
and easy!
User can control shapes, colors, patterns, lines spessor, and aspect of
internal text of boxes.
Object can be manipulated in the drawing in a very easy and intuitive way,
box can even be selected and copied via clipboard, pasting them and
obtaining again true 'flowchart box' with full possibility to manipulate
them in color, style size etc.
User can also control spessor of lines, use arrows, specifying type and
aspect, even specifying the angle of the arrow head. The environment offers
a lot of facilities to make the work easier.
A mouse grid can be defined to force allignament of boxes and lines.
The preferred measure unit can be selected from pixel, mm, cm, inches.
In any moment user can modify the working scale, more or less of 100 % and
work in the preferred scale.
Documents can be larger as the user likes.
The output can be printed using any Mac printer.
A fine control of the printing margin (using the selected measure unit) is
provided, for a true 'What You See Is What You Get'.
Using Flowchart Maker very complex flowcharts can be obtained in a short
time, in full color and ready to be printed on any Mac compatible printer.
This 1.3 version has lot of new features and bux fix!
Furter info at the Tension Software site at
